Security System Problem-Red key ON
Old 05-30-2012, 12:02 AM
blamecanada's Avatar
blamecanada
blamecanada is offline
Question Security System Problem-Red key ON
2007 Ultra Classic.
Driving to work today I noticed the little red security key was on, I figured that the fob key was dead or dieing so no big deal. After work I went to start the bike and the alarm did go off, so I figured its gotta be the key fob battery. I entered my security code with the turn signals and all was good.
When i got home I installed a brand new battery into the fob. But still the security alarm goes off. I had two brand new fob batteries and tried both and nothing will make the fob work.
Any idea what the issue or issues may be??
As I said, it will run fine if I enter the code manually with the turn signals----this will get to be a pain in the a$$ in no time---Any help would be great.
I'd love to avoid taking it to the stealer if possible as the nearest dealer is 3 hrs each way.
PS----I did try removing the 40 amp orange main fuse trick as I read on here, That didn't work
Thanks in advance!!!
Old 05-30-2012, 12:08 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
battery is the right way up ?
mike
Old 05-30-2012, 12:17 AM
blamecanada
Yes----double checked that also...LOL
Old 05-30-2012, 12:46 AM
meyhem's Avatar
meyhem
meyhem is offline
Have you tried your other fob, assuming you got 2 with the bike?
Possible your fob got fubar, according to the manual they can get "scrambled" it near other electronics.
Brought home new SG two weeks ago, found one fob not programmed to the bike from factory.
Hope it's something simple.
Old 05-30-2012, 12:58 AM
blamecanada
Sadly I only have one fob----i'm also guessing that the fob is screwed up.
Hopefully I can get one of the three stealers that are all a minimum of three hour drive each way to give me a decent estimate of parts and labour.
Hopefully this will be just a new fob and some labour to flash it!
I'll be making the calls tomorrow.
I'll post what ever the out come is.
Old 05-30-2012, 03:47 AM
geezer glide 56's Avatar
geezer glide 56
geezer glide 56 is offline
security antenna might have shifted or going bad.
Old 05-30-2012, 04:15 AM
dbell66253's Avatar
dbell66253
dbell66253 is offline
Check the TSSM and the antenna connection, make sure they're secure.
Old 05-30-2012, 04:19 AM
DOMAPOI's Avatar
DOMAPOI
DOMAPOI is offline
One of the things my manual says to do is put the fob on the drivers seat and start the bike. After starting you can put the fob anywhere you want. If that works it could be a weak fob or antenna problem.
Old 05-30-2012, 06:40 AM
HDV-GLIDE's Avatar
HDV-GLIDE
HDV-GLIDE is offline
Did you check for trouble codes through your odometer?
Old 05-30-2012, 07:06 AM
RoadhouseRG's Avatar
RoadhouseRG
RoadhouseRG is offline
Default rek key light on
I had the same issue with my '09 model.........found this thread on cvoharley.com
http://www.cvoharley.com/smf/index.php?topic=50747.0
hope this helps you out
Quick Reply: Security System Problem-Red key ON
