Oil pan gasket
09-16-2012, 11:26 AM
Oil pan gasket
I have a leaking oil pan gasket. Real basic question - can the pan be removed with the engine in the bike?
09-16-2012, 01:27 PM
Yes, necc to remove the rear wheel/swing arm for clearance. Check out Baker site and the +1 install instructions.
09-16-2012, 03:47 PM
09-16-2012, 05:35 PM
Yes you can. It is a giant PITA, but it can be done. I did it once to replace a leaking gasket and once to clean out the pan after a inner cam bearing failure. The second time around was definitely easier.
09-16-2012, 07:13 PM
Skip did you check tightness, mine was wet around pan an retorqueing them stopped.
09-17-2012, 08:19 AM
Torqued them all; did not seem to help
09-17-2012, 12:00 PM
did you check the bolts on the side cover of the trans?? the are a known issue...
09-17-2012, 04:28 PM
This is a 2005; different design.
bparsel
EVO
27
05-06-2021 06:01 AM
Sorce
07-14-2019 10:08 AM
LQQK_OUT
EVO
22
07-10-2016 11:25 AM
RVTRKN
04-27-2014 01:56 PM
Rhinoexpress
09-09-2007 08:32 PM
