Michelin Commander iii tire pressure question
Old 10-25-2012, 08:03 AM
Terrabella's Avatar
Terrabella
Terrabella is offline
Default Michelin Commander iii tire pressure question
Just purchased a set of Michelin Commander ii for my 2009 Ultra Classic. I have been running Dunlop 408/407 using 35 psi front \ 40 psi rear. Does anyone know what psi Michelin recommends for their Commander ii tires?
What I have read about this subject and it ranges all over the place from 35/40 to as much as 42/42 front and rear. The sidewall in the Cii states 42 psi max...but that is max. Any first hand info at there??
Old 10-25-2012, 08:13 AM
rossn2's Avatar
rossn2
rossn2 is offline
I run 40Rear/36Frt on my FLHTK in the Commander II's..no issues
Old 10-25-2012, 08:19 AM
jus2anoyu's Avatar
jus2anoyu
jus2anoyu is offline
I spoke with Michelin directly. "We recommend whatever the manufacturer of your motorcycle specifies in your owners manual" was their politically correct answer....
Old 10-25-2012, 08:58 AM
timvan's Avatar
timvan
timvan is offline
The tire manufactures don't specify the psi for a said vehicle, its the vehicle manufacture. Just run what the book tells you to
Old 10-25-2012, 09:15 AM
Guitardude's Avatar
Guitardude
Guitardude is offline
I'm running 38 front and 40 rear on both my Heritage and on my Road King...
With 5000 miles on them on the Heritage, down to 6/32's (9/32's new) tread depth front and rear. about 1/3 of the miles have been local fun riding and every day driving, 1/3 long weekend trips to ride the twisites and 1/3 on a long haul, 8 days to Arkanasa for BB&B by way of Hot Springs. LOVE the way they ride and GRAB the road!
Old 10-25-2012, 09:22 AM
mikelikesbikes's Avatar
mikelikesbikes
mikelikesbikes is offline
I got the same response when I contacted Dunlop about the E III's. I suspect any tire manufacturer will say the same.
Old 10-25-2012, 09:27 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Exclamation
That is not good advice! It is fine when fitting the same tyres as supplied on the vehicle when new, but not if changing to an alternative tyre or brand. Always check the tyre manufacturer's website. Some brands, including my own favourite Avon, may use quite different pressures. In this case it seems Michelin recommends the same as in the owners manual, but that should not be assumed.
Russdy (03-18-2022)
Old 10-25-2012, 09:35 AM
Terrabella's Avatar
Terrabella
Michelin website does not give a recommended psi that I can find anyway.
Old 10-25-2012, 09:39 AM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
Look on th side of the tire and find the max PSI. Run it close to that (within a few pounds) for the best life. On my Dyna with the Com II's I run 40 front and 42 rear. Ignore the Harley pressures in the manual as those are for the stock Dunlops which are a completely different tire.
Old 10-25-2012, 10:06 AM
grbrown's Avatar
grbrown
grbrown is offline
Wink
You could email them. When I have had tyre queries Avon has always answered promptly, I would hope the other brands do too!
Quick Reply: Michelin Commander iii tire pressure question
