2010 street glide looking for more power
I have a 2010 street glide with rinehart 3.5" pipes and a after market air cleaner with 27,000 miles I ride hard and fast and avg about 3,000 miles a month I'm in search of reliable engine upgrades that give you the most bang for your money I have looked at big bore kits, cams,and complete big bore engines, what are yalls thoughts on this. Any info will help, thanks
RaceStage IV kit done to my 103" motor and this is an all Harley build and does 117hp/111tq. The dyno shows a still climbing hp graph, and it is still a fairly steep climb even as the redline (now at 6250rpms) brings everything to a halt as spark is dropped from the ignition due to the redline... If it had continued to 6500 rpm it would have another 5 hp even if the rate of climb has started to decrease. And the tq is higher than stock from 2200 rpms all the way to red line by anywhere from 5 ft lbs to 9+.
Others may suggest a 120 complete motor, and I looked at that. The cost was nearly $2000 more for this option, the performance is better, lots more to be had in power. It was all the extra stuff required for the 120, intake, exhaust, tuner, and many more expensive parts.
My kit had the 58mm TB, cams, and everything else needed.
I have never gotten to ride a 120 on a touring bike either, it may be really good with all of the tq that comes naturally on the 120.
several options already suggested.
For $1700 and change out the door, my indy ordered and installed: from Fuelmoto a PowerVision tuner, and Woods TW222 cams.
I went with new lifters since the bike had 10,500 miles on it with the SE255 cams and stock lifters, so I picked Feuling lifters, and I decided to go with the new Redshift cam shoe tensioners -Zippers Performance has the cam shoes worth checking out.
Bike runs darn good.
See Fuelmoto site for dyno sheet on the cams.
3.5" pipes (2 into 2) suggest that you removed the 2 into 1, with a heavy breather. No mention of a tuner or having done a dyno to get it up to max performance 'before' upgrading further. no mention if cams have been changed. just wondering where you are at as a starting point.
Jarrod Miller
03-28-2016 09:53 AM
