Speaker Selector Switch
Does anyone know if the Ultra speaker selector switch can be used on a Street Glide to turn off the front speakers?
I have posted on other threads about this but have not gotten the answers I need. The switch is over $80 so I would rather know for sure before I throw that much money away.
If it can be done, I would appreciate some wiring information.
I had my inner fairing swapped out this weekend with a painted one and I would rather not mount switches in the new fairing like I had in the old one for a cleaner look.
The switch I'm talking about is a different animal. Instead of interrupting the speaker wires, it (from the best I can understand) turns off and on a circuit inside the radio. It only has 2 wires that actually control the speakers. The normal switch for something like this needs 4 wires.
however my speakers are at a fairly low level as my earbuds ( and the various ones i use are all the same) are much more efficient than the speakers, in fact I usually have to use an inline volume on the earbuds to get the signal to noise ratio up.
so at "normal" listening levels, my speakers are pretty much inaudible if I pop the earbuds out
If you wanted a switch, you'd have to use a dummy load on the amp
Mike
From the owners manual - the "off" position is what you seek I believe
"A three position speaker (SPKR) switch is located on the inner fairing cap of the FLHTCU and the FLTR. See FLHTCU SPKR Switch .
NOTE:
The SPKR switch found on the FLTR is inoperable.
Off/Forward: In the forward position, the speakers are off. Audio (radio, CD/MP3, AUX and CB) is played in the headsets only. During simultaneous CB reception, the other audio source is muted and only the CB is heard in the headsets.
Center: In the center position, the radio, CD/MP3 player or AUX is played over the speakers while the CB is played only in the headsets.
On/Rearward: In the rearward position, the speakers are on. With the SPKR indicator lit, the radio, the CD/MP3 player, or any AUX device and the CB are played through both the rider and passenger speakers. When a CB signal is received, other audio sources mute and the CB is played over the speakers. Refer to Audio Routing and Mixing Combinations.
NOTE:
The intercom is only heard in the headsets, regardless of the SPKR switch position."
NOTE:
NOTE:
NOTE:
NOTE:
NOTE:
NOTE:
I know that 2 of the 4 wires control the light and someone responded to my previous thread with:
There are only 2 wires that go up to the headunit. The Orange/Blue on Pin # 1 goes to the same power source that your radio goes to and supplies power to your switch light.
Black/Green is ground
Brown/Orange goes to pin # 13 on the 23 pin connector on the radio
Violet/Orange goes to pin # 21 on the 23 pin connector on the radio.
The above is simple enough but I was hoping someone that has installed one on their bike could verify the wiring and that the above would work before I bought an $85 switch to put in the drawer.
Ithink if you wire like the diagram I sent you it will work. Thats how mine works and I believe the street glide is no different as long as you wire it according to the diagram. You will get the light and all the same results. If you need more of the wiring diagram pm me.
