Keeping heated grips on 12" apes possible?
Old 12-16-2012, 07:23 AM
BaggerJohn's Avatar
BaggerJohn
BaggerJohn is offline
Default Keeping heated grips on 12" apes possible?
I want to install a set of 12" mini apes on my 12 Ultra Limited. I was told before that in order to do so, I would lose the heated grips because the bars are not made to transfer the grips over.
Has that changed? Does anyone know of a set of bars that will allow the heated grips and throttle by wire? Any info would be greatly appreciated. Thanks.
Old 12-16-2012, 08:27 AM
roadkil1995's Avatar
roadkil1995
roadkil1995 is offline
I just put a set of 12" apes on my 2010 flhtk.kept the heated grips no problem.just dont run your switch wiring thru the bars with heated grips.tbw was no problem bars were already notched for it.
Old 12-16-2012, 08:33 AM
MoChrome's Avatar
MoChrome
MoChrome is offline
I have HD heated grips internally wired with 10" Monkey Bagger Bars. I've also installed heated grips in Khrome Werks sweepers and 12" Monkey Bagger Bars. The only changes I made was to extend the wiring and notch out he left switch housing with a Dremel so I could run the wires internally. Maybe the inner dimesnsions of the bars you are considering are too small for the left grip to slide inside?
Old 12-16-2012, 09:23 AM
79289Chase's Avatar
79289Chase
79289Chase is offline
I have heard a lot of people say its not possible but I always wondered why.
Old 12-16-2012, 09:25 AM
Gonzy's Avatar
Gonzy
Gonzy is offline
Gonzy
I have the HD heated grips on my RG with 12" mini apes. Everything is wired internally, no problem.
Old 12-16-2012, 09:32 AM
big TYME's Avatar
big TYME
big TYME is offline
Wonder why it's not possible? Too many wires and/or the fact that the left side isn't notched for any wires. If its not notched, just cut a hole like mentioned b4. I have an 06 SG and would like to install some new bars but would like to keep my heated grips. Since mine is an 06, I don't have TBW so hoping someone can chime in with experience.
Old 12-16-2012, 10:29 AM
SanJuanRon's Avatar
SanJuanRon
SanJuanRon is offline
I have 14" HCC apes on my CVO Ultra and have the heated grips which work fine. SJ Ron
Old 12-16-2012, 12:53 PM
Lemayco's Avatar
Lemayco
Lemayco is offline
I installed heat demons on my 08 SG with 12" monkey bagger bars. We had to ream the bars to make the inside diameter large enough to accept the heating elements. I was hesitant about doing this to my brand new expensive bars but all went well and am happy I did it.
Old 12-17-2012, 02:07 AM
thor10000's Avatar
thor10000
thor10000 is offline
I have WO575"s with factory heated grips wired inside. The temperature control is on the left grip and takes up a little space. You have to trim about 3/8 inch off the left bar in order for the grip to but up to the 1 1/4" section. I have not had any problems. I did have 2 dealerships and Hill Country Customs tell me that the heated grips would not work on WO575 bars, they were wrong.
Old 12-17-2012, 03:12 AM
kateean2's Avatar
kateean2
kateean2 is offline
Quick Reply: Keeping heated grips on 12" apes possible?
