Fork oil
Old 12-16-2012, 09:10 PM
roaddr's Avatar
roaddr
roaddr is offline
Default Fork oil
How often should you change fork oil?
Old 12-16-2012, 09:18 PM
2black1s's Avatar
2black1s
2black1s is offline
The maintenance schedule in the service manual specifies 50,000.
Old 12-16-2012, 10:01 PM
06SuperG's Avatar
06SuperG
06SuperG is offline
I would recomend 20k.
Old 12-16-2012, 10:11 PM
PghCycle24's Avatar
PghCycle24
PghCycle24 is offline
Has anyone changed the fork oil using a heavier grade? The one thing I'm unhappy with on my '12 RGU is excessive front end dive during braking and low speed handling, and it was suggested to me that changing to a heavier fork oil would help with that.
Old 12-16-2012, 10:35 PM
2black1s's Avatar
2black1s
2black1s is offline
I did. And I didn't like it. While the heavier oil (SE Heavy) did improve the brake dive, it compromised other aspects of handling too much for my liking. My biggest issue with the heavier oil was that the front end seemed to be less planted as it would "pogo" over bumps in the road rather than follow the road. This was most noticeable through higher speed curves on a less than perfect road surface. This observation was on my Limited. The SE Heavy oil is fine in my Duece.
Old 12-16-2012, 11:28 PM
XARAN's Avatar
XARAN
XARAN is offline
Changing to a heavier oil will slow the action a little and you may like the ride all you can do is try for your self. I think they all ride better with heavier fork oil, I've changed all of my bikes. But in most cases a spring change with oil or better yet Mono tubes or valves with springs will make the biggest difference
I'm running Monotubes in my road glide and the forks are the best yet of all my HDs to date. My Fatboy and sportster had progressive springs and SE fork oil , I left my RKCuston stock and my road glide has the Monotubes
Old 12-17-2012, 05:25 AM
jus2anoyu's Avatar
jus2anoyu
jus2anoyu is offline
I changed mine at 20k and the oil was nasty. So nasty that I disassembled them and cleaned them. I was amazed that forks could get so much metal particles in the oil. I went with the se heavy fork oil and couldn't be happier. Much less brake dive and the bike seems more planted to the road....
Old 12-17-2012, 08:25 AM
btsom's Avatar
btsom
btsom is offline
The front forks vary by machine. In 08, at least, the fairing machines had extra valving in the forks not put in the Road King series. The results of heavier oil may be more noticeable in the forks with the extra valves. I went to 20 weight in my King and will try 30 on the next change. I suspect that if I had the other forks with the extra valve, the 20 wt. would be too stiff.
Old 12-17-2012, 09:48 AM
KCFLHRC's Avatar
KCFLHRC
KCFLHRC is offline
Received 1,300 Likes on 780 Posts
I tried the SE Heavy in my 11 RKC, bad mistake. Bike handled like $hit. Went back to a blend of stock and the Heavy and it worked out pretty well.
Old 12-17-2012, 09:53 AM
hardheaded's Avatar
hardheaded
hardheaded is offline
Received 2,482 Likes on 1,541 Posts
any recommendions for the fairing bikes?
Quick Reply: Fork oil
