Clutch type
12-23-2012, 08:46 PM
Clutch type
This might be a stupid question, but how can I tell if my clutch is hydraulic or not. Going to change my bars soon and need to know this. I got an 06 SG. Thanks for the help. I assume with a hydraulic clutch, there is fluid that runs the thru the line. I believe mine is not hydraulic because it has a cable running thru it.
12-23-2012, 08:48 PM
does it have a cable or tube for fluid.
12-23-2012, 08:49 PM
Do you have a clutch cable? Or a master cylinder? That's your answer.
12-23-2012, 08:50 PM
a hydraulic will have a master cylinder on the left side, similar to the master cylinder for the front brake on the rt side.
mike
12-23-2012, 08:51 PM
If its got an adjustment on the frame below the tank, then there has to be a cable right?
06 FLHX unless it was changed by someone, then it's not hydraulic. CVO's come with hydraulic, but doubt your bike has one.
12-23-2012, 08:52 PM
Quote:
Originally Posted by
big TYME
Yes, cable
12-23-2012, 08:59 PM
I feel real stupid for asking that question now. It makes perfect sense now. Just making sure before I ordered these cables. Getting closer to cruising with monkey bars. Thanks again fellow members.
CVO SG
Milwaukee Eight (M8)
07-11-2019 10:04 AM
hardheaded
07-30-2018 12:52 PM
cpc0812
04-26-2015 07:44 AM
cpc0812
Softail Parts
04-09-2015 05:32 PM
badbag
17
07-30-2009 12:58 AM
