Decat Pipes
Old 03-21-2013, 02:17 PM
hardheaded's Avatar
hardheaded
hardheaded is offline
Received 2,488 Likes on 1,544 Posts
Originally Posted by edtompkins
Going to try the core bit route this weekend. That with the Vieds and CVO baffles should make for a good weekend project.
core bit is not worth a dam, won't get it all out. 1 inch x 16 inch paddle bit and a bit of pry bar action and it's gone, all of it.
  #52
Old 03-21-2013, 09:16 PM
jg4660's Avatar
jg4660
jg4660 is offline
Originally Posted by Uncle Paul
A common method to get rid of cats is to buy one already decatted on the web (+/- $125).
Hang your old one in the garage for when you trade your bike in later. (Might be required)
Buy 3 new gaskets, and swap them out. Cheap and easy: >).
If things change, and they begin testing in your area, you still got your cats.
Yep...Thats what i did.....i noticed much less heat, better sound even with the stock pipes and no felt change in performance.
  #53
Old 03-22-2013, 06:33 AM
Voldemort's Avatar
Voldemort
Voldemort is offline
After looking at mine fore a couple of minutes I decided to cut pipe in two and drill it out. I will have a local guy weld it for me for a case of his favorite beverage. After about an hour of drilling, digging, scraping, and polishing I can't see how a guy can get it out and clean with a paddle bit. I did do something easier on the second half of the dig out. I used a small drill bit and repeatedly drilled around the perimeter of the cat material and wiggled the bit from side to side and by the time I got back to the place where I started it pulled right out. Then scraped and polished the inner wall and she was good.
  #54
Old 03-24-2013, 05:39 PM
dalv's Avatar
dalv
dalv is offline
Thumbs up Luv it!
Originally Posted by 2011FLHX103
This has been debated time and time again. You don't need to weld to take the 'cat' out of your stock headpipe. You can use a drill bit and get everything out quite easily (30 minutes and you're done). Buy a set of slip ons and hold off on the A/C until you can afford a tuner.
I second the suggestion to get in touch with Fuel Moto. Did my Stage 1 with their gear.
Kevin
Been lurking here and on other forums for the Decat. Planned on doing the door approach as I couldn't see cutting it in half. I kept looking at the header after I removed it and kicked around drilling it out (like I did with my '88 Alfa) but was gonna go with the tried and true method all the guys were suggesting until I came across this post. Seeing it could be done I decided to try knowing I could always cut the door if I had to.
It was a piece of cake - like noted above, 30 minutes with a $10 spade bit and some scraping with a homemade rod/washer set up cleaned it near perfect. So happy I had to put it back together to hear it run. OBTW '12 Roadie Ultra 103 is my new ride.
Now I just gotta figure out all the tuners, XiEd, etc. before moving on with more engine mods.
Wanna thank all you guys for the help. Love it when I can wrench on my ride and spend 10 bucks!
Ciao
  #55
Old 04-26-2013, 08:00 AM
Eagle240's Avatar
Eagle240
Eagle240 is offline
I just took my pipe off my 2013FLHX 2 nights ago and used the window technique method. The catalyst material was a motherfuXXer to remove - unsure how you folks do it with a drill!!!!
I scraped as much out with a screwdriver, and then i used a die grinder and made it smooth as could be.
Next goal was to re-weld panel and make it look as factory as possible. It took a little time but with help from a Uncle who has a Metal Fab shop - see the results:
D.Bob
06-14-2015 09:38 PM
Rudy2843
Exhaust System Topics
07-21-2014 11:28 PM
Tennblue
03-04-2014 01:50 PM
ajay450
11-08-2010 11:22 PM
Rex_Vaginas
02-26-2010 12:55 PM
Quick Reply: Decat Pipes
