Cranked my 09 SG and my front brake lever is hard as a rock when depressed. My bike has abs. The rear brakes are fine when depressed. Any idea why the front brakes won't depress?
Its been sitting for a week. I washed the front wheel but not the calipers. Frozen is the right word. Should I pull the pads and see if I can depress the pistons?
Open your bleeder screw and see if that relives the pressure first. That will save you having to file the piston. Mine did almost the same thing. Now I'm doing a full brake refurb. Good luck
