iPhone Charging Setup?
I have an iPHone 5...I have installed Carlini 16" gangster apes and when I did this I ran an internal USB cable from the battery area (not connected just a USB) and the small jack that goes to my book audio through the bars. I made a small hole (after consulting with Carlini about bar integrity) and have the iPhone 5 lighting jack and the 3mm cable hanging below the bend in the upper pull back area. I have a bracket on order and will mount the phone there (left side).
What I need to do is connect the USB to a fuse and then to the battery under the seat.
Can anyone provide specific parts needed to go from the bike battery through a fuse and into a USB cable?
I have two...
For a permanent mount I used a "Tapp Lite" waterproof port. This has an inline fuse between the battery and the USB port and is rated at 1 amp for the iPhone. They also make one in a 2 amp if you were wanting to charge an iPad.
http://www.pashnit.com/product/3br/3...p_usb.html#top
Having the original battery charger cable still installed, I picked up a SABEUS-1 so my wife can plug her iPhone in and charge it as well. Works pretty good and I can toss it to a buddy in need during a ride as well. Again, plugging into the charger cable uses another inline fuse.
http://www.burnsmoto.com/zoot-fresh-...sb-charger.php
Hope this helps!
Hope this helps!
I did the same as you, wire through the bar into the headlight housing, for my iPhone holder from http://www.michaelsstainlessinnovations.com/ . I bought a cheap charger for the cigarette lighter and opened up the case. When I got it opened it had a small fuse built into it. I wired it to run off of the accessory switch so I can turn it off when the phone it not attached. Mounted in the headlight nacelle is clean and dry. I see you do not need the charger for your cable but I thought others might be able to benefit from both installations. Good luck with yours.
Can you be more specific on how you did this? I guess the only challenge I have now is I've already ran the iPhone white cable through the bars and into the headlight area. So I need to be able to plug the USB end into the charger.
I looked in the Touring Models service manual and don't see anything about the auxiliary switch...any guidance would be great.
Hope this helps!
