60,000 mile Service
60,000 mile Service
Keepin mind: Bikes been in the shop forWarranty work only its entire life 100% - DIY is my creed, so I decided I need to trust my SJHarley Service team after 4 years deep breath here I go
Yep This is Me:
https://www.hdforums.com/forum/touring-models/364006-broken-frame-2009-flhtcu.html
https://www.hdforums.com/forum/touring-models/702644-2-times-rear-belt-broken-snaps.html
60,000mile Service $650
Includes: New: Steering Head Bearings / Fork Oil / Fuel Filter
Atthis point I could have done a Stage 4 Kit $1,800, but the Engine's been Solidand I'm looking to go another 60k with no problems..
TrannyBearing was done in December '12
My 3rd Belt I did at 40k miles
I'llupdate with Pics of parts replaced when she gets back
AddedWork: Total Cost $ 2,700- includes 60kservice
Wild 1WO 575B Replace Handle Bars / AllControl Cables / Polyurethane Bushings
Added: Audio XM Satellite Radio Kit-76404-06
Replace Cam Chain Tensioner
Replace Cam Bearings / Cam Kit
Replace Primary Chain Tensioner
Replace Piston / Rings
Replace Compensator - Use SE Compensator: 40274-08A
Replace 10mm Phat Spark Plug 32303-08
Problems:
RearAxle Nut Side Can not be adjust as outlined in service manual Can notget 100 Ft. Pounds of Torque Without itmoving
I haveElectrical Short Whining / Blinker Noise from Speakers - Applying brakes or Blinkers Voltage Drops below 12
Yep This is Me:
Problems:
Are you holding the left side of the axle with another wrench to prevent it from turning?
EDIT; just remembered that torquing the axle nut is a 2 step process. Lower torque setting initially confirm belt adjustment, then final torque.
I had the same problem with the axle moving when torqueing it up too. I smeared grease on the cams thinking that might work, it didn't. What I finally did was torque the rear axle nut to about 60 ft. lbs while it was on the jack and then drop it down to the ground and finish putting the rest of the torque to it. It seems to have worked the last three times.
Mr Vintage Machine
Classic
06-13-2007 04:26 AM
