How do you CALIBRATE a new HK Radio???
I need your help guys. I have a new replacement HK Radio for the 2006+ bikes. This radio came out of a kit that was to be an upgrade for pre 06 bikes to upgrade to the newer style. H.D. Part number 76412-06 I picked this up as a spare and am contemplating either keeping just in case I ever have an issue or selling it to someone that may need it here on the forum. I just hooked it up to be sure everything is in working order, the radio still has the protective film on the LED display. So I hook it up turn on the power and the first thing that the read out flashes is " RADIO HAS NOT BEEN CALIBRATED. All the systems are reading out correctly as far as recognizing the CB, the XM module etc..... and these all work as you can get stations and hear the CB and XM. But is also emitting a sharp two beeps every 5 seconds.
So how do I go about getting this radio calibrated to eliminate the beeping?? I am hopeful that I can do something other than taking it into a dealer to be "calibrated"...
Received 47,790 Likes
Uncle Larry and Pingman, Thanks for the replies and both of your adivce is spot on. So to update the thread and for others in the future. I spoke with a local dealer who stated that yep the digital tech was needed to be hooked up to it and cost would only be a small 20-30 fee if even that. I also e-mailed Tony at Iron Cross who has repaired another unit for me previously. They reaffirmed that the digital tech was needed and if I wanted to ship it to them they could do this on their bench.
