help with decel popping?
My current setup:
SuperFlow cat-less headers
Cobra Twin Slash-Down mufflers with baffles removed
Thunder Torque inserts from DK Customs ( they are local to me, met them yesterday, cool folks )
FL-ViED-10 - Have adjusted amount from the lowest setting of 25% all the way up to 75% and it doesn't seem to make a difference.
Before I got the Thunder Torque inserts, the torque on the low end of the curve suffered a big loss once I took the baffles out due to a loss of back pressure. The torque has been restored since installing the inserts.
Before I removed the baffles, I was already noticing plenty of popping on deceleration, so I wouldn't say that is the cause. Removing the baffles simply made it more obvious since it's noticeably louder now.
So, all of that being said... what can I do with my current setup to fix the deceleration popping? Would installing a Ness Big Sucker (or equiv A/C) help or would that hurt?
Thanks for any tips.
My current setup:
A/C is stock. That's why I asked if that would help. Though, I don't want to do it if it'll make it potentially worse ( not just for decel popping, but worse for engine w/o a "real" tuner and dyno ).
I have the dealer download which I got done when I bought my bike, rinehart 4 inch slip ons, screamin eagle air cleaner with the stock cover and FL ViED's bike runs flawlessly. Unless you plan on doing any further engine mods this set up should do the trick
I see... so doing the A/C will actually help overall and not hinder engine performance or anything? I just wanted to be sure before taking that last step.
The exhaust you installed lets more air/exhaust flow out of the engine than stock, but the engine is still only bringing in the stock amount of air. This screws up your fuel-to-air ratio.
You may see an increase or decrease in fuel efficiency once you change the air cleaner, but that will depend on the rest of your setup and how you modify your fuel map to account for the more "open" fuel/air system.
Stage 1 A/C will flow more definitely, add power but will probably make the decel popping worse, you need a tuner, Dynojet Power vision is a good one.
I'm not interested in more power. The original plan was just to add some volume / change the tone. I put the inserts in once I took the baffles out to restore the majority of the lost low-end torque. The power I have now is more than fine. So if the decel popping will only get worse, I'll skip the A/C.
