Voltage regulator gave up.
Old 05-26-2013, 01:09 AM
Ultra103's Avatar
Ultra103
Ultra103 is offline
Default Voltage regulator gave up.
2012 Ultra Limited, 6,500 miles. I had stopped off to buy some paint supplies at lunch time and the bike started running rough (pun intended) at the next light. I looked down to find a battery and check engine light on and the voltmeter was at 10.5V. I called the dealer and they said there is an open recall on the voltage regulator. The problem went away within a tenth of a mile but at stop lights the volts dropped to around 12.
Doesn't the MoCo send notices any more? The last bike had a rear brake hardware recall and I didn't get a notice for that either.
It's charging at 14.5V indicated now. I assume it's just the typical Harley bad gauge - it used to show 14V.
I must say, Pig Trail HD in Rogers, Ar. did OK once again. The bike was fixed the next day.
Old 05-26-2013, 01:38 AM
roadking48's Avatar
roadking48
roadking48 is offline
Default recall
Had a sent recall on my 2012 street glide. Dealer checked it out, said they'd already checked 25 bikes and all them were ok. Said they had to take voltage regulator off and read number to tell if it was one of bad ones. Some of there voltage regulator manuf. where ok, but number would tell. Of course mine first one they had to replace!!! I wondered as gauge was reading like 17 amps on gauge while riding. Now back to normal as other bikes I've owned.
Old 05-26-2013, 02:19 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
I know you mean 17 volts*...if for any length of time, that will damage the battery.
You may want to ask your dealer what solution they offer if the battery poops due to the voltage regulator fault.
Mike
* the in dash voltmeter is not very accurate... readings for diagnostics should be taken at the battery with a real voltmeter
Old 05-26-2013, 03:31 AM
jossi's Avatar
jossi
jossi is offline
6th Gear
Hi guys i have a 2011 SG when i check my gauge shows 15-16 V is that too much ?
Old 05-26-2013, 05:35 AM
tnbillybob's Avatar
tnbillybob
tnbillybob is offline
Jossi, my 2011 U/Limited shows 15/16v on gauge, bike has 39,000+ miles, no problems so far.
Old 05-26-2013, 05:47 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
15/16 sounds too high, however the voltmeter isn't particularly accurate. Well worth checking your charging circuits with a multimeter. There are instructions in the HDF DIY Electrical stickys.
Old 05-26-2013, 08:51 AM
BeavisRules's Avatar
BeavisRules
BeavisRules is offline
My 2012 road glide had the same thing happen but at 600 miles. It was a sad day seeing my new bike being pushed into a trailer for a ride to the dealership.
Glad they fixed you up.
LiveRound
Electrical/Lighting/Alarm
13
07-22-2020 10:14 PM
RideFree1267
11-28-2017 05:05 PM
jjkrueg
08-10-2014 01:28 PM
mwriggs
07-25-2012 11:41 AM
mwriggs
06-10-2012 12:43 AM
Quick Reply: Voltage regulator gave up.
