Roll off switch on cruise control necessary?
Old 06-20-2013, 06:02 PM
rando1954's Avatar
rando1954
rando1954 is offline
6th Gear
Default Roll off switch on cruise control necessary?
I installed a cruise control on my 02 FLHRI about 40k miles ago .
The throttle cable broke at the throttle handle and I want to know if it's necessary to have a throttle cable with the roll off switch.
Would it create problems if I just used a throttle cable without the roll off switch ?
I really never use that function when I 'm using the cruise .
Any help would be appreciated .
Old 06-20-2013, 06:16 PM
racklefratz's Avatar
racklefratz
racklefratz is offline
Originally Posted by rando1954
I want to know if it's necessary to have a throttle cable with the roll off switch....I really never use that function when I 'm using the cruise .
Of course it's unnecessary - you always have the option to cancel speed control however you want - you don't need anybody's permission for that. But if all you want to do at the time is cancel cruise control, and braking or clutching isn't in the plan, then the throttle switch becomes more important.
You 'da man - you make the call.
Old 06-20-2013, 06:22 PM
Stiggy's Avatar
Stiggy
Stiggy is online now
Received 5,555 Likes on 3,058 Posts
It's the idle cable that has the switch and the cruise will not work without it. I broke a throttle cable a couple of months back and while waiting for the new cable to come in, I ran the idle cable in the throttle slot for that week. The cruise wouldn't engage at all until both cables were back on where they belonged.
Old 06-20-2013, 06:41 PM
birdmandave's Avatar
birdmandave
birdmandave is offline
I had both cables replaced on my 01 UC without the roll off. Just had to tap brake or clutch and it worked okay. Got used to it pretty quick
Old 06-20-2013, 08:11 PM
rando1954's Avatar
rando1954
6th Gear
Stiggy you're right . It is on the idle cable .
I bought new Barnett cables for it only to realize after I started to tear it apart that the roll off switch was on it . I bought just standard cables .
It's been 10 + years since I replaced them and I forgot they were special .
I actually forgot about that feature (roll off) that I never used it . I've been tapping my brake / clutch to disengage it .
Old 06-20-2013, 08:17 PM
rando1954's Avatar
rando1954
6th Gear
SOOOOO , the standard cables will work with the cruise but I won't have the roll off function ?
Old 06-20-2013, 09:33 PM
0ldhippie's Avatar
0ldhippie
0ldhippie is offline
I use the cruise and roll-off all the time!!! Pretty silly not to put the right cable on and keep the roll off feature imho.
Old 06-20-2013, 09:36 PM
foxtrapper's Avatar
foxtrapper
foxtrapper is online now
Received 1,252 Likes on 815 Posts
I've got an 04 RKCi with working cruise control. Darned if there is any roll off function, and I don't remember ever seeing a switch at either end of the cables.
Old 06-20-2013, 09:57 PM
btsom's Avatar
btsom
btsom is offline
I would bet that the roll off switch is a lawyer switch. If it weren't there, somebody would sue. With the front brake switch, the rear brake switch, the clutch, the cruise on-off switch and ultimately the electrical master switch, there are plenty of ways to shut off even the most stubborn cruise control. That is at least one more redundant shutoff than in the typical car. Having TBW, the most common challenge for me is a smooth cruise disengagement. It is easy enough to use any of the functions, but they result in a jerk,as if the throttle had been snapped closed. I try to match twist grip position to throttle position when turning off the cruise so there is no jerking change of speed. Turning off the cruise with the roll off function guarantees a jerk from a sudden throttle closure so I never use it and wouldn't miss it.
NightRaven (03-25-2022)
Old 06-21-2013, 12:38 AM
FNGonaRK's Avatar
FNGonaRK
FNGonaRK is offline
Received 7,667 Likes on 2,676 Posts
Mine is too damn sensitive. I can't even lay a gloved hand on the top of it without turning the cruise off hitting bumps on the highway. I may look into disabling it.
Quick Reply: Roll off switch on cruise control necessary?
