Tribar taillight schematics?
Hi does anyone have the wiring diagram for a 2011 streetglide taillight circuit board that's located on the back of the lower taillight. I need it to wire up some aftermarket taillights with it so I can have two that signal and brake. Thanks don't need any suggestions just the what wires go where input and output side.
Ya I know the colors I need to know where they go into the circuit board, I don't have the plug on mine because I have sinister taillights. I want to use the circuit board to run my brake and turn signals at the same time so I need to know where the wires go in and out of the board.
Location: Western Illinois, land of bad roads, and corrupt politicians
Easy way to do it...................
If you have LED turn signals and a stabilizer, you can pick up the individual turn signal power at the stabilizer. The running lights and brakes from the connector under the rear of the left side cover, or under the seat at the ACC plug.
Green wire for running lights, and red for brakes..... and ground of course.
DickGrayson
04-09-2007 03:36 PM
