Lowering blocks
Some friendly advice, see the word SEARCH in the Blue Bar above, click on that and in the box that pops up, type in Lowering Blocks......Be prepared to read 100's of posts that give you the pros and cons of using them...
Received 3,941 Likes
I have seen the welded ones stretch and break.
Get one piece billet like THESE.
My opinion is that as with everything, moderation is the key. If all you do is a simple one inch lowering block, there's no cons. The bike sits an inch lower, the shock angle is only slightly changed but is still at less of an angle than a stock V-Rod shock, and your ride height is now the same as a stock Street Glide. If you go more than 1 inch, there's no pro's. You will constantly scrape, with a lot of weight you run the risk of damage to the fender and under fender components and you will bottom out. I just installed the Pingel one inch blocks. Problem free so far both solo and with the Mrs.. I will probably be installing an air ride system over the winter as I want more adjust-ability, but for now the 1 inch blocks did the trick to get my seat down to a more enjoyable height. But this is just my opinion, and opinions do vary.
