Grip Help!!!
Grip Help!!!
I must be getting old because my throttle hand likes to cramp up while riding, lol I'm not squeezing the bars to tight or anything like that either. Any thoughts on grips to help with cramping? I've seen the Avon Air Cushion grips and the Kuryakyn ISO grips so far...Any help would be great! Thanks!
Yeah, I was just hoping to get a lot of responses and maybe a couple will stick out that I can try.
I have the stock chrome rubber Harley grips and they stink! I tried a throttle boss and tension on the set screw....I'm thinkin I need alarger diameter softer grip. Which kinda sucks because years ago I used to run Baxter grips on my Springer....getting old I guess, lol
Try som grip puppies. Just foam tubes (treated so UVs don't break them down) that silp over your stock grips. Started using them years ago and the increased size pretty much eliminated any hand fatigue or cramping. Added benefit is that they're very inexpensive, easy to install (or remove) and you can find out if the increased size solves your problem before springing for new grips.
