"Cams Only" Upgrade: SE-255 Cams or Wood TW-555?
Old 10-19-2013, 11:01 AM
FenderGuy53's Avatar
FenderGuy53
FenderGuy53 is offline
Default "Cams Only" Upgrade: SE-255 or Wood TW-555?
While I'm very happy with my current Stage 1 upgrade, I MAY (operative word MAY) decide to install performance cams sometime down the road. IF I go that route, I want to do a "cams only" upgrade, and have that be the end of it (see my sig for current setup).
Question 1: Are the SE-255 and Wood TW-555 good options for me?
Question 2: How are the SE-255 and TW-555 cams similar/different?
I know that I'll have to move away from my XiED's with a cam upgrade, so which fuel management system is the easiest to install and the simplest to use, for a layperson?
Thanks for your insights, guys.
Old 10-19-2013, 11:19 AM
Dozer40's Avatar
Dozer40
Dozer40 is offline
The SE 255 cams are good with stock compression while the 555 likes about 10:2-10:5 compression. There are other cams for a 96 inch. Contact Scott at Hillsidecycles. The TTS system is a good bet for tuning made easier with the new Flight Recorder program.
Old 10-19-2013, 11:23 AM
jus2anoyu's Avatar
jus2anoyu
jus2anoyu is offline
The Andrews 48 was made specifically for the 96" baggers. They work very well. They are a non emission version of the 255's
Guitardude's Avatar
Guitardude
Guitardude is offline
Old 10-19-2013, 11:30 AM
Dozer40's Avatar
Dozer40
Dozer40 is offline
There are some people on this forum that think cam questions have been beat to death so why go there. I say F$#ck em. If they don't like the questions maybe they should put some pants on, tear themselves away from the keyboard and go ride.
Old 10-19-2013, 11:37 AM
OldPhat's Avatar
OldPhat
OldPhat is offline
SE-204 another cam to consiter too.
Old 10-19-2013, 11:39 AM
Sam2010's Avatar
Sam2010
Sam2010 is offline
woods 222
jus2anoyu's Avatar
jus2anoyu
True. And they have an incredible sound!
Old 10-19-2013, 12:39 PM
jeg1's Avatar
jeg1
jeg1 is offline
Originally Posted by Sam2010
woods 222
Yes happy with mine. To the OP I don't think SE -255 are a good idea in a 96 unless you add compression relases
Old 10-19-2013, 12:46 PM
tully_mars's Avatar
tully_mars
tully_mars is offline
If you are willing to pay for a Woods cam then the best option is a TW-222 if you are considering a SE255. The 222 will produce more torque for a longer range and more horsepower because of its longer duration.
As said already the 555 in a stock motor on a bagger will feel almost no different that what it does now till you hit 3200 rpm then it will pull. Just not a low end torque cam with stock compression.
I am a low rpm torque guy, and I have yet to find a better low end torque cam for a stock engine setup with better support from vendor (FuelMoto) than the Woods TW-222 combined with a Power Vision tuner and supplied map. Once I install this setup and then Autotune Basic with it, it is good to go. Very simple setup and saves money.
It also is easy to change in the future if you decide to do more to the engine.
Quick Reply: "Cams Only" Upgrade: SE-255 Cams or Wood TW-555?
