TC 88 cam conversion
So I'm contemplating a cam change and hydraulic tensioner upgrade on my Stage 1 TC 88. I've been reviewing archived threads on the swap, but most of the posts date back to when 88's were the norm, no such thing as a 103 or 110 yet. Most threads sourced the parts from Zanotti's, and recommend a Herko (Hercko?) kit. Both of those sources appear defunct now. Andrews lists part number 288902 as the conversion kit using it's N series cams, but it's not found on fleabay or on Amazon. I know I can source the individual parts via the MoCo, but I like the idea of an all inclusive kit. If you've done your TC 88, please share your experiences with me. Trying to learn all I can, what would you do differently if you did it again. And please, I'm not talking a particular cam choice but rather the swap in general terms. Thanks.
Andrews got bitch slapped by H-D for selling a complete kit using the H-D retro fit kit with Andrews cams. That is why you won't find it on their site. I believe a call or e-mail to them will get you what you need. I got mine from American Classic Motors on-line, but it did not come with the roller chain on the inside. I didn't do enough research before. I believe if you were to get the H-D kit #25384-11 and Andrews N cams of your choice with the inner roller chain, you'll be set.
I have a 2000 Wideglide with 42,000 miles and I switched out the cams and tensioners in January last year.
Since the bike lived 13 years and 42K miles I didn't think it was really necessary to go all hydraulic. I just replaced the cams with Andrews 21's and replaced the tensioner shoes with the ones from Cyco. (inner bearings replaced as well.) These tensioner pads are cheap, maybe $20 for a set or $60 if you buy the little tool they sell for install/removal.
Removed and installed the cams with heat instead of the press. Check out this link for details. Only special tool I bought was the Gary Beatty inner bearing installer/remover.
http://harleyhog.host.sk/tensionerinstall.htm
But, ya know, if it ain't broke, why fix it, I reckon...for me, I'd just rather take that possibility off the road forever...
I'm not worried about the original shoes at this point. While I do have an older bike, it's only got 10.5k miles on it. I'm thinking more about the torque gained by a cam change than the tensioner issue, but might as well address it while I'm in there. The gear drive is dependant on run out specs, so I'll just assume mine is out of spec and do chains. After looking up some costs it would seem that I'm looking at around $660 for the HD parts through Surdyke (Upgrade kit, cam spacers, gaskets and SE pushrods), $230 for an Andrews N series cam on ebay, and whatever an oil change costs. Am I missing something?
