Vibration when leaned left?
Old 02-21-2014, 07:46 AM
Tennblue's Avatar
Tennblue
Tennblue is offline
Default Vibration when leaned left?
Kind of hard to describe, but I am trying to chase down a noise/vibration in the front end of my 12 Harley Ultra Limited (16,000 miles). When I lean the bike just a little (like to change lanes) I get a little bit of a whirr noise and the slightest hint of a vibration. Doesn't happen when running straight, or when making the same maneuver to the right. Only to the left. Also does not happen when banked hard (like for a sweeper turn, or a turn at an intersection).
First thought was a bearing just starting to act up. Or maybe a little loose? Or could just be tire whine, but only on one side?
Any ideas or anybody ever have this happen to them? Figured I would throw it out here first. My next step is pulling the front wheel and checking the bearings....
Old 02-21-2014, 08:01 AM
0ldhippie's Avatar
0ldhippie
0ldhippie is offline
I'm gonna guess, Wheel bearing...
Old 02-21-2014, 08:03 AM
dynhd1's Avatar
dynhd1
dynhd1 is offline
Old 02-21-2014, 08:06 AM
jeffreydsilver's Avatar
jeffreydsilver
jeffreydsilver is offline
wheel bearing
Old 02-21-2014, 08:19 AM
TBoat's Avatar
TBoat
TBoat is offline
I had the same thing on my 09, only when leaned to the left. It was my rear tire. Replaced it and not more whirr noise.
Old 02-21-2014, 08:26 AM
Joe12RK's Avatar
Joe12RK
Joe12RK is offline
Received 1,410 Likes on 880 Posts
I had the same problem on mine. Dealer found bad wheel bearing and replaced it. No change in vibration. They and another dealer said cupped rear tire was the cause. I just put new tires on the bike but it'll be a few months before I can ride. Hopefully that'll fix the problem because warantee is over. Joe
Old 02-21-2014, 08:33 AM
JohnnyC's Avatar
JohnnyC
JohnnyC is offline
I've changed my front tire twice, had the bearings checked and repacked and I have the same exact issue. Going down a smooth road and just shifting to the left it still feels like a bad bearing but isn't.
It's so minor I don't let it distract me too much. Everything is solid and tight.
I've wondered if my alignment may be off just a little.
I'll be interested in hearing others comment on this post.
Old 02-21-2014, 08:46 AM
wing_rdr's Avatar
wing_rdr
wing_rdr is offline
Originally Posted by dynhd1
Check for rear wheel alignment . Friend of mine had same issue and that is what the problem was.
Old 02-21-2014, 08:53 AM
dulley's Avatar
dulley
dulley is offline
on my 2011 it was rear tire . dealer said put 42 pounds in it , it was gone I ran 35 it was cupping very little .
Old 02-21-2014, 09:30 AM
Sprinter7x's Avatar
Sprinter7x
Sprinter7x is offline
Had same symptoms on my then new 12 RKC,took it for granted dealer had checked tire pressure,they hadn't.Filled the tires up to proper pressure and it went away.
Quick Reply: Vibration when leaned left?
