Brake pad wear
Old 03-04-2014, 11:20 PM
reddog8145's Avatar
reddog8145
reddog8145 is offline
Default Brake pad wear
When I had my 2012 RKC 10,000 ml service my dealer pointed out that the brake pads on the left hand front calliper had worn down more than the right and needed replacing. The difference was not all that much with approx 1000 miles wear on the other calliper left. The dealer said this was nothing unusual but I'm not so sure about that. Anyone else ever experienced this sort of thing.
Old 03-04-2014, 11:58 PM
Hausguy's Avatar
Hausguy
Hausguy is offline
Nope. I just changed the fronts on mine at 31K and they were about 50%. Rear looked better so I left it.
Old 03-05-2014, 12:56 AM
garyFLHPI's Avatar
garyFLHPI
garyFLHPI is offline
My brakes don't last more than 12 - 13k.
Old 03-05-2014, 05:13 AM
bald1der's Avatar
bald1der
bald1der is offline
34000, I'm on my 3rd set of brakes. I admittedly ride kind of hard. I do notice that both sides don't wear exactly the same. Not enough of a difference to alarm me though.
Old 03-05-2014, 07:16 AM
BigDawgQC's Avatar
BigDawgQC
BigDawgQC is offline
I got 28K out of the original pads.
Old 03-05-2014, 08:20 AM
TWIN CAM 96's Avatar
TWIN CAM 96
TWIN CAM 96 is offline
replaced rears once but still running fronts from stock @ 27,000 maybe replace them by next year.
Old 03-05-2014, 08:29 AM
ynots's Avatar
ynots
ynots is offline
Id try bleeding the right caliper
Old 03-05-2014, 09:08 AM
TWIN CAM 96
That should do it
Old 03-05-2014, 11:14 AM
Hogpro's Avatar
Hogpro
Hogpro is offline
Former Sponsor
You should also remove the pads and clean the pistons in the caliper to ensure that they are sliding in and out of their bores smoothly. Excess brake dust can cause the pistons to stick causing uneven brake pad wear. Use brake cleaner and a wire brush or an old tooth brush and before you put it back together watch the pistons to ensure they slide in out smoothly.
Old 03-05-2014, 01:35 PM
capnray's Avatar
capnray
capnray is offline
Stage III
I had the same reaction when I first looked at my front pads. I noticed the pads "look" thin but wear slow. I have 17000 on my 2013 FLHRC and just keep an eye on them.
Quick Reply: Brake pad wear
