Cam change-what all will I need
Im fixing to do a cam change on my 2012 road king. Have I left anything out? S&s quickie pushrod kit, cam cover gasket, cam bearings, oil pump o rings, Andrews 57H cam, assembly lube? Will I need anything else? Last cam change I did was on a 87 evo 10 years ago.
Fuel Moto has a complete cam swap package ; http://www.fuelmotousa.com/performance-cams.html
some folks prefer using SE pushrods
Make sure the pushrod kit has the pushrod covers also as the stock covers will not work as there is insufficient room to adjust the pushrods.
Replacement lifters would be a good idea. I used Gatermans and they have worked great. http://www.gatermanproducts.com/index_files/Page410.htm
Will also need the cam gear spacer kit (25928-06) Harley sells to make sure your cam and crank gears are properly aligned. Will need feeler gauges, at the very least a .010 gauge.
A good idea is the cam gear locking tool so you can remove the cam and crank gear bolts. If you are re-using the old lifters, get the magnetic tool Harley (and others) sell to use to hold the lifters up while you do the cam change.
Another real good idea is changing the stock oil bypass spring to the Baisley spring, it will increase oil pressure and help keep the lifters pumped up with the extra strain on them from the higher lift cams. http://www.baisley.com/oil_spring_product.htm
Definitely will need the tool to remove and replace inner cam bearings. I went with one with a "window" cut into the plate to make it easier to see what you are doing. They are all over Ebay for a bit over $100. http://www.ebay.com/itm/Harley-David...a61875&vxp=mtr
I used the Screamin Eagle EZ install pushrods in mine. They work great and are very easy to adjust since the pushrod tube uses 4 flats instead of the regular 6 sided ones. Makes it easier, for me at least, to know how many turns you have made.
I already am running power commander V, decated head pipe and fm dyno tuned jackpots and full flow breather. I was mainly talking about what gaskets would I need. I would like to try and order everything at one time. Ke5rbd I have book marked a thread where you had posted a map for the 57H. Picking a cam has been hard for me. Is there a cam other than the 57 that you would recommend. Of course money is an issue. The economy in my area isn't booming to well.
