my front brake lever has become really stiff to pull what do I need to look at . it seems to work fine , no drag and brakes are fine but just really stiff to pull . any help would be appreciated .
Assuming you have an 08 based upon your profile pic, your brake fluid should have been changed 3 times already during the life of the bike and the brake lever service pin should have been changed at a minimum of 3 times, has any of that been completed?
Any chance the cable is hanging up in the housing? maybe dirt or something has built up in the housing? I don't know if that is possible but just a thought.
If your master cylinder is DOT4 DON'T use the DOT5. They don't play well together.
Unless you flush it through with 2 cans.
Your piston is probably dirty. If you crack the bleeder while pulling the lever does the fluid come out and lever drop?
