I am having a terrible time with rings.... My jugs measure 3.875"-3.876", I'm using Wiseco 4993PS pistons with 3875VM rings. All told, I have 4 sets of rings here, and everyone of them out of the package gaps at about .022"
The instructions that cam from Wiseco for Harley Twin Cams say top and bottom ring should be gapped at .015"
According to previous post, .022" is within Harley's specs for ring end gap, but I would be contacting who sold you the pistons and rings to confirm this.
I believe H-D's gap figures are the preferable ones to use. JIMS also uses the same numbers. Assuming all your measurements are correct you're Ok to go.
belive ring gap is 5 tho for every inch of bore, so around .20 for both top and middle ring is minimum. rather be to big than to small. to small will bind the rings when they get hot and ruin your top end.
