Blinkers fast flash and one rear doesnt work
Ok guys, need help before i buy a $150 tsm (turn signal module).
2006 flhxi (street glide) 22,000 miles. Lowered, airnott air suspension, led accent lights. Everything else is stock. All lights and blinkers are stock.
Had a run,turn,brake light module that i believe went bad causing issues with my blinkers. I removed the module and still has the same symptoms. Which are as follows. Right blinkers work front and rear, but they only flash 3-4 times normally before they begin fast flash like a bulb is out. Left side, only front works normally for 3-4 flashes before it begins fast flash. Have changed rear bulbs and moved them from left to right with same symtoms.
Left rear blinker does not work at all.
Thanks for the responses. Got the rear light working, crappy plastic cup thingy that holds the wire had let go. Got it fixed and now the blinker works. Now here is something i learned yesterday.... If the bike is not running. The blinkers flash normally, but when it is running they fast flash.
Regular factory bulbs, no led bulbs.
PistonPuller
02-23-2006 09:55 AM
