Hammock seat and "standard" Rider Backrest
I loved the standard (52589-09A) backrest on my UC until I put a Hammock seat on. The Hammock sets you back and the backrest feels to be setup for the stock seat that seems more forward to me. I read where guys bent the standard backrest to push it back some.
My question is, would the adjustable backrest (52596-09A) fix the issue? It looks like you can adjust the height and the angle of the backrest pad but does the actual backrest bar recline towards the passenger seating area? I feel like if it was back a inch or two, I'd get the best of the Hammock seat.
Thoughts? Thanks in advance!
Found something interesting here. Looks like if you want to run a solo seat, which I do with my quick connect tour pak kit, you can't run leave the adjustable hardware underneath. Also, someone mentions the standard backrest has a few adjustments on forward and back. Going to the garage to see if that's true...
https://www.hdforums.com/forum/touri...back-rest.html
You cant run the adjustable on the hammock because the frame pushes up the seat mainly for the passenger.
I fixed mine free by cutting the frame down to 1 hole and welding it all back together, works great. If you find the back to close then heat the 2 half inch rods up and bend them to where ever you want.
