Which Ride Height Do You Prefer: Street Glide vs. Road King/Electra Glide?
I have a 2011 Street Glide with Bitubo shocks in the rear (stock Street Glide length, 300mm) and Traxxion Dynamics AK-20 front suspension. The overall ride height of this bike is ~1" lower than a stock HD Touring bike, such as a Road King or Electra Glide.
Thanks to the above aftermarket suspension, I have no complaints regarding ride comfort or handling, even with the reduced ride height.
However, the bike does occasionally bottom out when exiting a driveway or parking lot when making a sharp turn. When riding two-up, the rear shocks will also occasionally bottom out when going over a large pothole, etc (I'm being fussy here, Folks. The bike rides exceptionally well).
I'm now considering going with full length Bitubos in the rear (330mm), but it would be an expensive endeavor.
What is there to be gained by switching from a Street Glide sized shock (300mm) to a full length rear shock (330mm)?
Thanks
Thanks
However, the Bitubos, even the 12", give an amazing, plush ride.
I'm looking to see if there is any additional benefit to going to a full length Bitubo.
Thanks
To answer your original question, the stock 13" shocks of the ultra will have more travel and cushion the ride more than the 12" SG shocks. There is the difference in static height too. I have an 07 ultra and rode a friend's 07 SG all day. Mine was more comfortable, it sat up (slightly) higher but more travel in the bumps. I didn't notice the height difference all that much, suspension travel, yes.
I have since moved to progressive 444 shocks in the rear, even better.
Or does the 13" shock handle better in sweepers?
Thanks
Does the stock 13" ride height handle any better than the 12" height, or is it just more comfortable?
Thanks
some say no- but...
increased ride height gives more lean angle.
the comfort when touring is much better- thats why i swap shocks...50% more suspension travel...add in that is also takes longer in time for the suspension to move from each extreme of the travel.
for me to comfortably do 8 to 10 hour days in the saddle, day after day, I need comfort. An Ultra seat and the 13's with correct air pressure.
when in town and in the saddle for only a few hours at a time, 12's and a flhx or solo seat are fine ƒor me
mike
mike
