Anyone have a portacath?
When riding the movement from my shirt rubs the skin over the portacath and becomes irritated. I tried using a bandage / tape to cover it but my problem is that also irritates when I pull it off for a while. What do you do about it? I have tried tucking my shirt in tight but the wind still blows my shirt in that area.
I don't have one, but do have experience with various types of medical "overlays"
After trying everything available in the pharmacies, I found an excellent product that I use to keep medical patches in place. ALL the others were really irritating my skin, especially when taking them off. I'd end up tearing the skin away, and causing all sorts of problems.
I have to use these mostly in the summer as the heat causes the glue to fail on the patch, then it falls off, and I'm not getting the meds.
Also use them in the shower, another place the patch might fall off.
These are absolutely necessary for me to get the meds at the proper rate, and have used them for almost 10 years.
IF, you leave them on for too long they will also cause some irritation, but if you change them often, it's not a problem. There are sticky across the entire membrane, not just the edges, so I'm not sure if you could use them in your situation.
Hope this helps
Oh, I found that the pads they give you with tens machines are HORRIBLE to use, the glue is way to strong, and you end up tearing skin if left on for too long. Plus, it was next to impossible to get the dirty layers of glue around the edges off, especially if used on the back, hard to get to, and that glue was like impossible to get off.
They are cheaper if you buy 50, I'm lucky, my patch maker gives them out for free!
If you want, I could send you a couple to try out, let me know.
Amazon.com: Bioclusive Transparent Dressings #2463 (4x5"""") (by the Each)"""": Health & Personal Care
Hope this helps
What about trying a Tegaderm dressing? They come in different sizes. They're clear, stick well, but are also pretty easy to remove. I've used them for years at work, and I think I saw only a couple people have any kind of reaction, and even then it was only mild. You could also try something like an snug fitting Under Armour type shirt. Just a couple of ideas...
http://www.underarmour.com/shop/us/e...pid1253237-025
I don't have one, but a friend of mine that used to fly has one. How long have you had it for? Jim has had his for a little over a year. When he got his, he also retired and started riding much more. He says it took six months for his skin to toughen up and shirts not to irritate. His is on his right chest and he wears the "wife beater" under shirts and said that helped him. Other than that, I could see getting some of the larger tens pads or defib pads might do the trick.
