Front brake pulse - new parts, no change
Started using the front brakes a lot more, noticed pulsing bad like warped rotors. Looked closely at the rotors and they were trashed. Unevenly worn, deep grooves, etc. I did NOT take a dial indicator to them as they looked bad enough to replace.
Replaced the rotors, pads and cleaned the front brake calipers. Rode the bike to work today and you can't tell I did a damn thing. No change at all.
The dealer had put the new Dunlop 402 front tire on backward a long time ago so took it to them while off and they reversed it and said it balanced out fine. Has 5 ounces of weight total on it, 2.5 oz. per side. It might have about 3000 miles left on it. I did this before swapping the rotors out so I know they didn't bend my new rotors.
I know I need to lift it and check runout on the new rotors but have a feeling that they're good. Bad tire (out of round) or bad wheel (rotor to wheel surface)?
Anyone been through this? Curious what it was if not the rotors. I'll lift it tonight to see what I can see.
You running a spoked wheel or cast? I think I would have replaced the tire being it was that low. This is very strange, shouldnt have these issues after replacing rotors. Have you checked your wheel bearings or the tire may be the culprit. Does it only react when applying the brakes or can you feel any vibes when off the brakes?
The wheel bearings were good and snug when I had it apart. If you hit the front brakes hard going 40 or so you can feel a very slight vibration. At low speed such as coming to a stop it lurches bad.
I wasn't going to give the dealership the privilege of taking my money on a new tire. Reversing it was no charge because they mounted it wrong to begin with. They made enough mistakes that I won't go back.
