Premium Hand Adjustable Touring shocks
Hello, Looking to replace the air shocks on my 2011 Limited. Checking out my options and when looking at the hand adjustable premiums I notice it seems the only adjustment is on the left shock. Just seems kind of odd to me. The shocks have great reviews and they are on my shortlist. Anyone care to comment? Thank you.
Rick
Rick
I put them on my 13 limited and like them very much. The left side (with ****) is your compression side. The right is rebound. HD figured since the new swing arm is redesigned and beefier this setup will work (09 and newer)and it's a lot better than the factory air shocks in my opinion. I've read and believe it takes roughly 750 to 1500 miles for these shocks to break in and then you'll find you'll be able to dial them in as to riding solo or 2 up. Cargo amount will play into it also. Hope this helps.
Rick
Rick
Yes, you only adjust one side.
They work great!
100% better than the factory air shocks.
Of course they won't be as good as something like Ohlin's.
If you weigh less than 220 and ride solo it does not need to be adjusted either. Leave it on the softest setting. I have had mine on for about 20k miles. Vast improvement over stock. I got the 13" version. I can't deal with 12" shocks as the ride is rougher and the bike scrapes the ground too often.
