mounting Inspection tags?
I guess I am in violation then I removed a transmission bolt on the right side and put the tag on it. I couldn't find a more clear spot for it to be seen. I'll check again tomorrow to see if I overlooked a spot.
When I bought my TG in Virginia, the dealer mounted a custom-made plate on a frame bolt beneath the left side passenger floor board. Dealer probably had a bunch of them stamped out. The plate just cleared the cross-over exhaust pipe. It could easily be seen by law enforcement.
I see you're from Virginia. Dealer was Patriot HD in Fairfax.
Thanks I'll check out that spot this morning.
