Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Chrome Metal Valve stems
Old 02-21-2015, 04:05 PM
scuba1954's Avatar
scuba1954
scuba1954 is offline
Default Chrome Metal Valve stems
Does anyone on this site have chrome metal valve stems in there wheels? I have a garmin 590LM that can monitor tire air pressure but they require metal valve stems to be used. I am on ***** Shiny's waiting list for a new set of chrome rims, forks, rotors, spacers and baby moons so I would also like to find some chrome metal stems to compliment the new rims.
Thanks in advance.
Old 02-21-2015, 04:17 PM
FuzzyWuzHe's Avatar
FuzzyWuzHe
FuzzyWuzHe is offline
I mentioned this on TT ... I think I saw some on JP cycles.
Old 02-21-2015, 05:46 PM
BinIdaho's Avatar
BinIdaho
BinIdaho is offline
I have chrome covers and screw-on caps on my valve stems...got them free at Les Schwab.
Old 02-22-2015, 02:05 AM
gusotto's Avatar
gusotto
gusotto is offline
Chrome (metal) valve stems are what are needed. Not just a pretty chrome cover.
(Centrifical force.)
They are needed when using the tire pressure monitoring caps.
Rubber valve stems with the little added weight of the TP monitoring caps can (maybe) cause the rubber to split.
Not a hard thing to get.
Just make sure when getting tires installed, they know you want steel stems.
I had them installed at my indy dealer when I got new tires.
Old 02-22-2015, 08:00 AM
scuba1954's Avatar
scuba1954
Let me make sure I understand you correctly. You do have chrome METAL valve stems and they are on your factory rims on your Harley Trike? You said you had them installed at your INDY dealer. I am assuming this is a Harley dealer, would you have their name and I will call them and see if I can get them to send me three...thanks
Old 02-22-2015, 10:46 AM
FuzzyWuzHe's Avatar
FuzzyWuzHe
If you go to J&P cycles, do a search for valve stems, you'll find these and lots of others.
J&P Part: 217-395
F150HD (05-01-2017)
Old 02-22-2015, 04:24 PM
gusotto's Avatar
gusotto
gusotto is offline
I had metal stems installed on my Ultra.
I'me running Tire Gard air pressure screw-ons and they recommend metal stems.
Getting metal stems isn't a big deal.
wwwjpcycles.com part number is VS1218R.
Old 02-23-2015, 06:24 AM
scuba1954's Avatar
scuba1954
It may not be a big deal getting them but I am concerned about figment on the front wheel since my dealer said they won't fit the trikes wheel. That's why I'm asking if anyone with a trike has the on their factory style wheels.
Old 04-29-2017, 10:07 AM
F150HD's Avatar
F150HD
F150HD is offline
Received 1,270 Likes on 836 Posts
do these last for years? or need routine replacement like a rubber valve stems?
what mileage do they last?
Old 05-01-2017, 08:52 AM
HOGN IT's Avatar
HOGN IT
HOGN IT is offline
Default I Just Posted a Reply re: Tire Press Mon Sys but relates to metal valve stems
Link is here, if anyone's interested. Posted pics of metal valve stems also:
https://www.hdforums.com/forum/tri-g...l#post16191843
Quick Reply: Chrome Metal Valve stems
