HD Heated Pants 98327-15VM
I don't have heated pants but I do have heated gloves and a heated jacket liner with a dual controller.
I leather pants over my jeans and I'd suggest that if you're doing the same that you try the heated pants on before buying them to make sure they're large enough.
My leather pants are a size bigger (2") than my jeans and due to their weight I wear both a belt and suspenders.
The heated pants won't be nearly as heavy as leather but make sure they won't slide down!
You could also have some that go over or under your pants, and wear a pair of chaps; or skip the heated gear and just wear the chaps.
Yeah, I know, old heavy, cumbersome, hard to put on and store chaps, but...
Take a look at these.
www.coloradochaps.com
Nylon, Cordura, Balistic Nylon and Kevlar chaps that are light, very easy to put on even without having to sit down, and don't take up much room when folded up in their pouch. There's a velcro loop that goes around your belt to hold them up. And you can get them fleece lined or mesh backed or whatever options you want. Reasonably priced, and custom fitted.
In fact, when you order them you give them a bunch of measurements and how you want them to fit, and you get an amazingly well fitting and comfortable pair, you really hardly know you are wearing them. I'd advise calling instead of using the form, and they'll walk you through it.
I got a pair six months ago, ballistic nylon with leather pipe patch on the right side only. I use a pair of suspenders or carabiners to hold them up because I don't wear a belt ('cause I got no a$$.) They don't tend to fall down anyway. They were about $135. Just a very satisfied customer.
Oh, and the ballistic nylon does a tremendous job of stopping the wind and rain. Apparently so do the standard nylon and Cordura, but not quite as well. The Kevlar, not so much, it's porous but tough as nails.
Tell Lorna that I sent you. Super nice lady.
Update
I had a chance to test ride the pants yesterday. The temp was not real cold, about 38 degrees. I went with long underwear under the HD pants. I also had heated HD jacket liner, HD heated gloves and I also heated grips. I put a ski mask on under my helmet. I had everything set to Med (amber) and took off. I have to say everything worked pretty darn good. I was plenty warm except for my feet. I ended up putting a heat pack in my boots which really helped. My next test is to go for a ride when it is in the 20's. About the only advice I would give on the pants is to get a bar of soap and slick up the zippers before you use them. They are a little stiff at first and it really helps.
coronetracer65 (01-22-2017)
I use an unscented wax candle for stuff like that, stole it from the wife. I keep one in the junk drawer, one in the garage, and one in the basement shop, where it won't draw moisture like soap. Lots of uses; ease wood screw install.
Oh, for temporary, quick waterproofing of a piece of material, here's a trick; rub it all over with a wax candle, and then hit it with a hair dryer. It melts the wax into the cloth. A lot of commercial waterproofers are just wax dissolved in something that evaporates, does the exact same thing.
Knuckles73
10-25-2013 07:48 AM
