Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
TG Modifications – The ABC’s of Removing Rider Heat A + B = C
Old 06-04-2014, 06:56 AM
msocko3's Avatar
msocko3
msocko3 is offline
Originally Posted by coronetracer65
I have a 2014 Triglide and am experiencing heat when it is 90 degrees + So if I do exhaust and a tuner I can getby with the stock air cleaner ? Thanks . Ebert
No problem sticking with the stock air cleaner.
  #142
Old 06-05-2014, 11:41 AM
johnmicb's Avatar
johnmicb
johnmicb is offline
3rd Gear
Default Excellent Write-up
Thanks, just bought a trike. This will be very helpful.
  #143
Old 12-13-2014, 05:13 PM
Davewfc603's Avatar
Davewfc603
Davewfc603 is offline
Stage I
Default 2013 trike what changes to make with only a little knowledge
Hi , 1st post, I've been reading,rereading & maybe I'm right or wrong. Opinions would be appreciated.
OK, 2013 tri glide, under warranty/till 2019. Concern of warranty hassles. I still have all my stock parts. I have de-cated a stock header & added an Arlene Ness stage 1.all with the stock mufflers. Installing a Master tuner is next.
Could/should I have have started with the tuner 1st. ?
I understand that with what I have already done (de-cat/stage 1) and adding a tuner will make more power,torque, AND less heat. I "heard" the stock header with the cat removed has the O2 sensors in a poor location & should get an aftermarket header.
Thanks in advance Dave
  #144
Old 12-13-2014, 07:05 PM
Mr. Wizard's Avatar
Mr. Wizard
Mr. Wizard is offline
Administrator
Received 2,035 Likes on 1,103 Posts
An aftermarket head pipe will give you an immediate HP an TQ gain over a decat stock head pipe. The stock sensor locations are fine. The crosstalk suspicion on a decat stock head pipe was proved to be a non issue.
If it were me... I would put the stock air cleaner back on until you get your Tuner. You are running a risk of the ECM not being able to adjust completely for the change in both the pipe and air cleaner. This could result in excessive heat while riding and possible engine damage.
  #145
Old 08-29-2021, 06:10 PM
Mr. Wizard's Avatar
Mr. Wizard
Administrator
Interesting enough... this thread still applies today, 11 years later.
-W
Cagmo (09-01-2021)
Joe from So Cal
08-04-2018 07:44 AM
torchmaster
Milwaukee Eight (M8)
10-04-2017 07:33 PM
stal94gt
07-03-2015 11:42 AM
UTES
16
08-16-2013 04:24 PM
Ramboamt
07-30-2012 11:43 AM
Quick Reply: TG Modifications – The ABC’s of Removing Rider Heat A + B = C
