Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Fork tube swap write up...
Old 09-05-2016, 11:12 AM
usmc68's Avatar
usmc68
usmc68 is offline
How come I can't see pictures ? I'm logged in but X is in picture spot . I realize this is a older post I remember being able to see pics when it was first posted . Now that I need to replace front fork parts Info is all that shows up . What am I doing wrong?
Old 09-05-2016, 11:52 AM
Mr. Wizard's Avatar
Mr. Wizard
Mr. Wizard is offline
Administrator
Received 2,035 Likes on 1,103 Posts
It looks like the imageshack account of the OP has been shut down. I do know imageshack went from a free to a pay photo album site.
There isn't anything we can do about it unless the OP moves to another picture host or edits his post with the pictures uploaded to this site.
Old 09-05-2016, 01:09 PM
usmc68's Avatar
usmc68
usmc68 is offline
Thanks for the info . I had it saved in my favorites knowing I would need it some day I have the service manual so I can manage .
Old 09-05-2016, 01:46 PM
msocko3's Avatar
msocko3
msocko3 is offline
Follow the manual and you'll be fine, it's actually a pretty easy job.
Old 09-08-2016, 07:00 PM
usmc68's Avatar
usmc68
usmc68 is offline
got the job done .not a hard job with the right tools. now a question . My 2012 trike manual calls for 11.8 oz or 350cc of H.D type E hyd. fork oil Do any of You know if I use Screaming Eagle fork oil would I use the same amount of a lesser amount due to S.E. fork oil being for a stiffer ride?
Old 09-09-2016, 04:08 AM
msocko3's Avatar
msocko3
msocko3 is offline
Use the same amount, it's just going to ride a little stiffer. I've always just refilled with the oil called for.
usmc68 (09-09-2016)
Old 04-13-2017, 04:00 PM
laabdog's Avatar
laabdog
laabdog is offline
Default 2016 triglide
Wanting to change lower fork slider and upper fork sliders to chrome. Harley book states that lowers are part number 4550020 and uppers are 4560022 that is all fine and said. But I look for spacers for my axle so they would be chrome and there's nothing for my trike. Also where do you drain the fork oil there is no place at all and how much do yo put in each fork
thank you
Old 06-06-2017, 07:25 PM
PosseRider's Avatar
PosseRider
PosseRider is offline
There is no drain on the 16's. You have to remove forks & turn upside down to drain.
Old 07-03-2018, 07:47 AM
Free Bird Too's Avatar
Free Bird Too
Free Bird Too is offline
6th Gear
Does anyone make 49MM Fork tubes for the Freewheeler? I am replacing the stock trees with a set of custom machined reversion trees that look more like a wide glide and am looking to go a little overstock length on the tubes. I am having problems finding them. Forks by Frank used to be the go to guy... not for these. Lil' help?
Here's my ride.....
Dfriz (01-14-2024)
timberland
03-04-2018 09:44 AM
Spazz
2014-2023 Touring Models
53
01-08-2018 11:49 PM
crashnasty559
03-22-2016 02:27 AM
VooDoo13
10-19-2012 01:26 PM
VooDoo13
02-17-2012 09:21 PM
Quick Reply: Fork tube swap write up...
