Cornering issues
Cornering issues
Not sure how some people on this chat line tell me that they can keep up with two wheel bikes through the twistees ????? I have road everything from rockets to Ultra's ! I have a 2014 Tri Glide that I have put on 8000 miles on it . I just did the Lolo Pass in Idaho . 190 miles of 40 mph corners ! My 2 wheelie buddies ( Victory's ) had a hay day ! If you want to do 40mph plus you fight every corner ! I have tried six ways to sunday of styles of riding it to make it better ??? My arms were ready to fall off by the 100 mile marker ! Looks like it is time to hit the gym !!! Cant sell it as my wife will kill me ! She loves it !!!!!
Any help would be great
Bandit
Bandit
The trike will do it. It's gonna wear you out doing it though. That front wheel has to be held through the whole curve. The lift kit may help but I'm afraid the steering is just what it is. I've been surprised at what they are capable of on curves but you do pay the price in the shoulder and arm dept.
Dont know if it'll work for you but this is what I do for twisties and aggressive riding.
1. Lean, not as must as on two wheels, different type of lean. I look over the inside of the fairing on the inner part of the curve. Have the passenger do the same if one is aboard.
2. Put a bit of pressure on the outside floorboard, this helps keep you centered.
3. Have you gear already selected if you can, no shifting in the corner.
4 stiffen the outside forearm, helps with keeping pressure on the bars.
I move around quite a lot when running the curves...
A no BS reply
IMHO
...the lift kit(s) do not make turning in the twisties easier. If anything, they shift a bit more weight to the front wheel. Not sure how folks think that makes it easier to turn.
...the force on your arms is proportional to speed and tightness of the turn. No matter what you do, it comes down to how many Ft-lbs of pressure you need on the bars.
... Yeah for a couple of turns, I can keep up with a similar sized touring bike. His max speed in a turn is when the boards drag, mine is how much force my arms can take. After a bunch of tight turns my arms do start to ache.
...as a general rule, I stick to the posted recommended curve speed, and I'm fine. Any more than that anyway, and you can't stop in your vision field.
Btw...I have joke dwith people, and said that because of my second point above, I am not strong enough to flip the Trike.
Thanks for the replies ! I have a DK lift kit on it ! I have tried these suggestions ! On normal rode's this hold true ! I am talking highlighted roads from my HD map book ! The LOLO pass I believe has 180 plus corners in 190 miles ! It follows a river all the way ! Some sections are more like a figure 8 ! The two wheel buddies are traveling at 60mph plus around all of them ! As for pushing and pulling .? The right turns are some what easier as I can push on the left hand bar ! But when I make a left I have to also have to run the throttle ! Hence pull more with the left hand ! At the posted corner speed you can feel the trike fight back on most corners ! The pushing the front feel ! Only once did I get into a corner to hot and the front end got loose as the back tire started to lift ! Yikes ... hard on the heart to say the least ! Not whinning , just looking for some input on how to make it better , or live with it !Other wise the tri glide is great ! Just ask my wife..hee, hee
Thanks again for the input .
