Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Tri Glide Rear Shock Inflation
Old 10-19-2010, 05:17 PM
Diesel-Dawg's Avatar
Diesel-Dawg
Diesel-Dawg is offline
Default Tri Glide Rear Shock Inflation
Do any of you bother to inflate your rear shocks and if so, what poundage do you normally run with and without luggage?
Where do you find the air shock inflation studs? One for each side?
thanks
Old 10-19-2010, 06:20 PM
Tri Glide's Avatar
Tri Glide
Tri Glide is offline
I run 50 lbs. all the time. The valve is right behind the right side side cover. This is all explained in the owners manuel, if you don`t have one get one.
Old 10-20-2010, 03:18 AM
msocko3's Avatar
msocko3
msocko3 is offline
As Tri Glide said its behind the right cover. Make sure you invest in the correct air pump for it from the dealer, don't use the air compressor unless you desire some new shocks. You will have to experiment with how much pressure you like, I use 45 in mine and I'm no light weight.
Old 10-20-2010, 04:23 AM
oldmsocko's Avatar
oldmsocko
oldmsocko is offline
I run between 44 and 48 all the time. Its all a matter in the ride.
Old 10-20-2010, 08:10 AM
JSH's Avatar
JSH
JSH is offline
Michele and I got in a local "around the corner" ride Sunday. I pulled over after bottoming out ... was running 35 lbs ... bumped it up to 50. Michele could not believe the difference in the ride. I use the BushTec air pump that I got when I purchased the trailer.
Old 10-20-2010, 09:08 AM
icebite1's Avatar
icebite1
icebite1 is offline
33 lbs in wifes tri. but we never ride 2up and its a XXX so not as much weight. as stated above get the right pump, makes it easy and accurate.
Old 10-20-2010, 01:18 PM
Diesel-Dawg
I have a bicycle handpump with built-in guage that I use for my 18-speed bike. Will that do to pump up the shocks?
Old 10-20-2010, 03:51 PM
oldmsocko's Avatar
oldmsocko
It will do as far as not having too much pressure for fear of blowing them up. What the HD pump does is you can attach and detach it and not loose any pressure.
Old 10-20-2010, 09:39 PM
dw2169's Avatar
dw2169
dw2169 is offline
I had a Lehman Kit on a 08 Ultra and ran 36 lbs in it. Just got my 11 TriGlide and noticed most here run higher air pressure. Is there a difference between them?
Old 10-20-2010, 11:11 PM
Casper's Avatar
Casper
Casper is offline
Run 50 2 up. Solo about 35-40
Quick Reply: Tri Glide Rear Shock Inflation
