Vance & Hines Vance & Hines is product design and manufacturing company that produces high quality, high margin Performance Products within the Powersports industry.
FP3 recommended parameters in tables
Old 08-04-2016, 10:47 AM
rauchman's Avatar
rauchman
rauchman is offline
Received 3,239 Likes on 1,255 Posts
Default FP3 recommended parameters in tables
Greetings,
Just installed an Andrews 57H cam on my Switchback. By the way, originally started the map with the new cam from an existing map. I found it was better to start from scratch with loading in my setup (ProPipe, High Flow AC and Andrews 57H). I ran auto tune for about 100 miles or so, and while the bike is smoother, the exhaust smells like it's very rich. Also getting error codes stating that both the front and rear cylinder are running rich.
I've read that I need to keep autotuning, which I plan to do. In conjunction with that, is there somewhere that lists out what would be the ideal settings for all the tables....A/F ratio VE's, etc? I'd like to know if the auto tuning is getting there, or if I should manually change some parameters.
Thanks!
Gordon61
The Dyno Room
81
12-07-2022 07:44 AM
Gordon61
25
07-21-2015 05:13 AM
The Roadrunner
03-27-2012 08:00 PM
skully1200
08-06-2011 03:52 PM
VTwinJaxFL
36
05-22-2008 03:34 PM
Quick Reply: FP3 recommended parameters in tables
