How to ID stock spoke wheels?
Old 10-05-2015, 08:36 PM
nellis003's Avatar
nellis003
nellis003 is offline
Default How to ID stock spoke wheels?
Hi all,
I have a pair of spoke wheels that I bought at a swap meet. I'd like to use them on my 03 Road King but the bearings are 3/4". I bought a set of the 1" bearings, but the outer diameter is definitely too large on the front wheel and looks a little too large for the rear wheel. The 3/4 bearings are the old grease packed ones, not the newer sealed bearings.
Is there any way to identify these wheels so I can get the right size bearings? They each have a "HD" cast into the hub, and there are a few other marks as well. I've attached pics below.
Anyone know if these marks can be decoded?
Thanks,
Nick
Attached Thumbnails How to ID stock spoke wheels?-img_9996.jpg   How to ID stock spoke wheels?-img_9991.jpg   How to ID stock spoke wheels?-img_9993.jpg   How to ID stock spoke wheels?-img_9995.jpg
Old 10-08-2015, 03:58 PM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,240 Likes on 1,816 Posts
For your 2003 RK, I don't think you'll find any 1" ID x 1.781" OD bearings (i think that's the Outer Race O.D. of those 1999-earlier tapered roller bearings) plus other hurdles regarding rotors and pulley.
There are some sealed ball bearings out there to fit 3/4" ID x 1.781" OD, but that won't help you.
I think your best bet would be to get some later Touring wheels for an easy swap
Old 10-12-2015, 02:07 PM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
Unfortunately your wire wheels are the older spec wheels, off an earlier model, which are not suitable for your bike, there are no bearings that will enable you to make them work.
RED04FXD
Wheels/Tires
03-16-2018 10:17 AM
Egldr05
09-26-2008 06:13 PM
renoa18
05-06-2008 10:04 PM
nervousnorm
04-21-2007 01:00 PM
hogheadRW
12-21-2006 11:51 PM
Quick Reply: How to ID stock spoke wheels?
