Mu 85
BTW, your first ride with the AE's are probably gonna feel pretty squirrely. Not to worry, they are just very responsive and you will get accustomed to it. Good choice of tires in my opinion!!!
MU's are 140mm wide. The "85" or "90" refers to aspect ratio, meaning the MU90 is a taller 140mm wide tire than an MU85. The MU90 would probably fit in the fender, but the MU85 would be closer to the stock diameter. Both fit the wheel the same.
True. You should be able to run up to a 160/60-18 without mods
Not in my experience, but certainly a 150/80 will fit. Be sure to check the load rating, as some versions of that size are lower than is suitable for a dresser.
