front wheel wobble?
front wheel wobble?
SO I've been having this problem for a while now. I hit 70mph on the freeway and my front wheel starts wobbling to the point i have to slow down to get it back under control. the CHP cop ******* even said he could see it wobbling before he pulled me over and gave me a speeding tix, O he was on a bike too. The bike has 27k miles on it, I have no idea if the tires were ever changed, the bike was my dad's and he was the second owner. He hardly put any miles on it and it sat unridden for probably yrs at a time, so I'm thinkin maybe the tires need to be balanced or replaced or maybe a front stabilizer, who knows? has anyone had this problem and fixed it? thanks
Front Wheel Wobble
The only way to find it is to track them all one at a time (or all at once if you don't care which one it is)
1. spokes
2. tire pressure
3. tire condition
4. tire balance
5. fall away test, if necessary tighten star nut or steering bearings
6. check alignment
7. change fork oil
8. check motor mounts (for rubber mounted bikes)
1. spokes
2. tire pressure
3. tire condition
4. tire balance
6. check alignment
7. change fork oil
1. spokes
2. tire pressure
3. tire condition
4. tire balance
6. check alignment
7. change fork oil
1. spokes
2. tire pressure
3. tire condition
4. tire balance
6. check alignment
7. change fork oil
Yyou are absolutely right, but since the tires are obvioulsy very old, I'd still change them first - and then proceed down your list if the wobble persists. Old tires have other problems, like not gripping the pavement well, and should be replaced.
If you're changing the tires anyway, might as well adjust the neck bearings and change the fork oil. The wife's deluxe had a similar problem at a lower speed so I replaced the oil (stock oil looked like used 30W and smelled like a septic tank) and tightened the bearings. Immediate solution!
