Infotainment "Favorite Button" issue
I think the issue may be specific to the ipod media selection? Using a USB flash drive, it goes back OK each time. Using the ipod via USB it sometimes works, but mostly doesn't work? Could it be because the 6.5GT doesn't recognize/find the last point of play correctly for the ipod? Maybe the ipod needs to be stopped so it stays at the same point of play when it is "resumed"? IDK, just thinking out loud...
I have had my bike for almost 2 years. Only listen to the USB thumbdrive.
Every time I turn on the bike, the last song playing on the thumbdrive starts up.
Dealer did the 1.19.0 update while I was in for clutch recall.
Now, when the bike starts up, sometimes it starts with FM radio, sometimes it is weather band, sometimes it is USB
Freakin' annoying!
Had to finally activate the "favorite" button. Pain in the ****, but easier than toggling though the steps with the joysticks or getting finger prints on the screen.
dealer is "looking into it"....LOL
Freakin' annoying!
Since I downloaded 1.19.1, my bike returns to the last media I was using. So, if I turned it off with the USB running, when I turned it back on, it goes back to USP.
Thats the reason I tuned to the radio so I could see if the FAV was working.
I have an IPOD - will hok that up and go to fav - see if it returns when I turn the bike off - and if not, if the fav will work.
OK - I am back.
I disconnected my USB thumb and connected my IPOD. All music is playing and I can see the names of the songs.
While playing, I hit and held the favorites button, it displayed and listed mine as IPOD. All is well. Turned the bike off..waited for all to clear (IPOD still connected) and turned i back on, It started to play my IPOD - I didn't have to do anything.
Next, I changed from IPOD to radio. Turned it off - disconnected the IPOD. Turned it on..radio came on. Connected the IPOD - it went right to the IPOD.
OK - so, I next, changed it back to the radio (IPOD still connected). Turned it off. When I turned it back on, it went to the radio. I hit the favorite button.. if identified my IPOD as undefined, started to play it..then changes undefined to IPOD.
Sounds like mine is working. Are you sure you have 1.19.1?.
OK - I am back.
I appreciate you taking the time to check that out for me. This let's me know to pursue this as a warranty issue or not. The last thing I want is an untrained service tech wrenching around on the bike and nothing gets fixed and then a scratch here or there or even bigger problems.
OK - I am back.
A lot of this is interesting - we basically have te same radio - and the same fortware. I just wonder why it might be different.
One last thing to consider - try this. Go back to 1.18.1.... after that uploads, then try to upload the new 1.19.1. Shouldn't make any difference - but I came from 1.18.1 to 1/19/1.
The button holds it's memory during the same ignition cycle so I know the button works but once shut down, it looses it. It has to be in the software somewhere. Just a guess but maybe the newer updates are using more resident memory and there's none available for that part of the system. Who knows. It's really just a trivial problem but that's a feature I really use as it's a great shortcut from having to go through so many screens to change the music source.
2014-2023 Touring Models
07-18-2015 01:33 PM
