2014 Infotainment DTC screen access
Old Oct 13, 2013 | 06:59 AM
richvz's Avatar
richvz
Default 2014 Infotainment DTC screen access
I have read the manual for the infotainment system a couple of times. Tried to find it in the service manual with out any luck.
I have tried the instructions for the old system but that doesn't seam to work either.
I was wondering if anybody knew how to access it and could post the instructions.
I know how to get the error codes from the odometer screen, but the screen on the Infotainment system has more diagnostics than just the error codes
Old Nov 7, 2013 | 03:08 PM
dubiez's Avatar
dubiez
6th Gear
On bike startup press and hold the power button (on the right bottom side of the display)
Old Nov 7, 2013 | 04:44 PM
biglipps66's Avatar
biglipps66
Sounds neat Im going to try this on my way home
Old Nov 7, 2013 | 10:23 PM
cfreeze's Avatar
cfreeze
Hold the power button in while turning the ign to the acc position,until the warning screen appears.
release button and click on accept, the service menu will appear.
click on DTC option.
don't mess with the component or version options.
Old Nov 17, 2013 | 06:08 PM
richvz's Avatar
richvz
I haven't checked this post in while.
Thank you for the information.
There are other things you can access from this menu which is actually what I wanted. You can check and see if your switches are working on you handle bars or your tour pack without having to get you volt meter out to see if they are working.
the_ogre25
2014-2024 Touring Models
Mar 13, 2020 02:31 PM
jmbear328
22
Aug 4, 2019 01:49 PM
Amagalous
Apr 12, 2018 12:04 PM
TimLScheffer
135
Jun 24, 2016 07:12 AM
rwven
May 17, 2016 12:01 PM
