Extra
Extra
I am wanting to add additional lighting to my 2014 Limited. The dealer tells me that I may not add lights that they have to go through the computer. Wondering if I am being fed a bill of goods? Or...if I am being sold more labor costs? Can't I wire direct to the battery with a fuse?
Yesterday I added Custom Dynamics - Dynamic Ringz to my 2014 Street Glide. Last May
I added H-D a LED, Run-Brake-Turn Lamp to my saddlebags, it came with a controller.
Yesterday my turn signals flashed rapidly at first, then I put the Bikes flashers on for 1
minute, now it works normally. Add the Lights yourself, the new Can Bus system is suppose
be LED compatible on all Rushmores.
I'm getting ready to add LED Driving lights to my highway bars and I want them on when I have my high beam on so I am planning on taping into the high beam wire for the power. That way when the high beam is on, they will be as well. Tell me if you think this won't work.....
You CAN wire direct to the battery, but make sure you use a relay (and of course a fuse). If you want the lights to come on with the high beams, tag the trigger wire from the relay into the highbeam wire. It works just fine. I'm using 2 Hella halogen driving lights wired like that with no problems.
