2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
water pump & thermostat
Old 06-19-2016, 07:43 PM
plongson's Avatar
plongson
plongson is offline
24K no problems
Old 06-19-2016, 08:02 PM
MikeyTX's Avatar
MikeyTX
MikeyTX is offline
Originally Posted by hardheaded
how many people are having failures ? waterpumps ? thermostats ? HD should give everyone an extended five year warrenty on their twin cooled bikes if failure rates are high enough. a $400 waterpump and a $75 thermostat is outragous for cheap Chinese substandard parts.
Proof the parts are from China ? Oh heck, tri geezer beat me to it
Old 06-19-2016, 08:52 PM
austinrngr's Avatar
austinrngr
austinrngr is offline
6th Gear
I have a 2016 road glide ultra and my thermostat went out at about 700 miles. Had it replaced under warranty and its been fine since. I only have 2300 miles now
Old 06-19-2016, 09:03 PM
CSMHOG's Avatar
CSMHOG
CSMHOG is offline
2015 Limited with 30,000 miles. Just changed my coolant per the maintenance schedule. No issues with the cooling system at all.
Old 06-19-2016, 09:13 PM
cycle7447's Avatar
cycle7447
cycle7447 is online now
Received 1,716 Likes on 1,042 Posts
21,000 on mine - no problems
Old 06-19-2016, 09:24 PM
tpcowfish's Avatar
tpcowfish
tpcowfish is offline
At Just over 25,000, pump failure , right after 2 year warranty was over, Harley fixed under warranty
Old 06-19-2016, 10:30 PM
SpiderPig's Avatar
SpiderPig
SpiderPig is offline
How often do these fans run? I have only heard them run once when I turned the bike off and it was only for a very short while. How would one know if you had a pump or thermostat failure? I was out today in 95 degree weather for severaal hours and I didn't notice them on at all.
Old 06-19-2016, 11:54 PM
harley0711's Avatar
harley0711
harley0711 is offline
ride to Palm Desert / Palm Springs CA tomorrow if you want to test you coolant and fans,, tomorrow temps are suppose to reach 123
BTW - Parts are from China - It was ON the Internet, lol
M Oclaf (07-18-2023)
Old 06-20-2016, 04:11 AM
CSMHOG's Avatar
CSMHOG
CSMHOG is offline
The fans cycle on/off while the engine is running, depending on the vehicle speed and coolant temperature. If the fans are running when the engine is stopped, the fans and water pump will continue to run until the coolant is at 203 degrees F or for 3 minutes, whichever occurs first. If the fans aren't running when the engine is stopped, they will not run again with the ignition OFF.
Fan Operation
On (below 15 mph) - 221 degrees F
Off (below 15 mph) - 203 degrees F
On (above 15 mph) - 244 degrees F
Off (above 15 mph) - 230 degrees F
The following 3 users liked this post by CSMHOG:
Boat Racer (06-26-2016), GalvTexGuy (06-20-2016), SpiderPig (06-20-2016)
Old 06-20-2016, 04:50 AM
SpiderPig's Avatar
SpiderPig
Fan Operation
Thanks, I really appreciate the reply and details on the fan operation and temps.
Quick Reply: water pump & thermostat
