activating ABS HCU after brake fluid flush
I have been reading about the importance of activating the HCU after a brake fluid flush to get the clean fluid into it. How is this done? I assume you have to mash the brake pedal while in motion to get the unit to pulsate, which in turn moves the old fluid out. I don't mind doing that on the rear, however mashing the front brake while in motion sounds too scary. I know that going to the dealer is the best bet to service the HCU, but I am trying to do this on my own if possible. I can live with the old fluid in the HCU circulating with the new. I am hoping the HCU can be activated somehow at a dead stop but I am probably dreaming.
I have a road near my house that's down hill and has waves/bumps in the pavement. It doesn't take a lot to activate ABS front or rear when braking on a road like that. Barring a bumpy downhill, it can be done on wet pavement pretty easy as well as gravel. But frankly, you should go to a parking lot and find the point were ABS engages on all types of surfaces, it'll make you a better rider.
One caveat, don't purposely engage ABS when the run out is short and you HAVE to stop. Engaging ABS increases stopping distance over stopping without engaging it.
One of the good folks on this forum posted this link, so I'm passin' it on. http://www.daytona-twintec.com/Twin_Scan3.html
I'm' not sure if it works on the Rushmores. I emailed their tech dept. and should know soon.
Maybe start and ride it a short way to activate the ABS and then jack it up while it's still running and try out your method? I would think that might work.
