2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
EZ Clutch type ball and ramp
Old 04-22-2024, 06:56 PM
billgran's Avatar
billgran
billgran is offline
Default EZ Clutch type ball and ramp
My arthritis is acting up and holding the clutch in while stopping and starting in heavy traffic is becoming a pain. (pun intended)
My 2022 has the cable actuated clutch and for the older cable bikes, a ball and ramp kit worked wonders. I cannot find a kit for the current model bikes. I really don't want to buy the special clutch levers that are supposed to help.
Old 04-22-2024, 08:42 PM
Black Ultra's Avatar
Black Ultra
Black Ultra is offline
Muller and Advanblack both have them.
Muller:
Muller Motorcycle Power Clutch - 67-010-0 - Dennis Kirk
Old 04-23-2024, 09:09 AM
pyuchem's Avatar
pyuchem
pyuchem is online now
I’m looking forward to report from someone using this plus adjustable clutch lever on newer bikes with cable clutch.
My 2016 has hydraulic clutch. I’ve muller + Oberon adjustable clutch lever, I have small fingers so like the lever to be closer to the grip.
My lever is set at 5 and it’s just a tad bit difficult to shift, I can feel gear grind if I shift below 3k RPM. I have to be mindful of that and also make sure lever is pulled all the way in touching grips when I shift.
To be frank I would like my lever even closer than where it’s at but doubt I’ll be able to shift.
Old 04-23-2024, 09:52 AM
CanadianRocky's Avatar
CanadianRocky
CanadianRocky is offline
Received 20,390 Likes on 9,037 Posts
I had a recluse clutch installed in my 2017… When you stop the motorcycle, you do not need to pull the clutch in… Disengages all by itself below a certain RPM… Once you throttle up the clutch engages and you do not need to use a clutch lever to get going…
… Mana from heaven in stop and go traffic…
Old 04-23-2024, 10:05 AM
Oko's Avatar
Oko
Oko is online now
Received 3,916 Likes on 1,472 Posts
I have an hydraulic clutch on my ‘16 FLHTK.
I’m in the same boat as you.
I went with the softbrake reduced reach lever It made a BIG difference.
Then I added the Mueller.
My lever pull, IMO, pulls like butter.
But if it gets to a point where this set up doesn’t work to for me, I’d look hard at the Rekluse system.
Getting old ain’t for the timid!
The following 2 users liked this post by Oko:
aggiedude (04-23-2024), CanadianRocky (04-23-2024)
Old 04-23-2024, 05:47 PM
aggiedude's Avatar
aggiedude
aggiedude is offline
I did the Softbrake https://softbrake.com/product/2017-a...raulic-clutch/ clutch and brake lever's as well and couldn't be happier....I've got severe arthritis in both thumb to wrist areas, and these helped a ton. I wasn't sure what to do when I went to the hydraulic system, but then someone mentioned Rick and Debbie at Softbrake and it's been a blessing since...
Old 04-23-2024, 06:02 PM
Rounders's Avatar
Rounders
Rounders is online now
Received 1,912 Likes on 1,505 Posts
Didn't the easy ramp become stock around 2007? Is that why you can't find it for your year? As said maybe some other set ups.
Also lubing the cable does wonder. Every time I do it I swear I will do it more often. Which may be something to think about too. Lube pivot point too.
deacon1984
06-10-2022 07:51 AM
Kwest88
05-18-2015 01:00 PM
SANTA DEUCE
12-30-2012 07:51 PM
BlackFLHR
05-05-2010 06:43 AM
ThePointman
03-13-2009 05:06 PM
Quick Reply: EZ Clutch type ball and ramp
