infotainment stops playing music.
Hi i have a 2014 limited cvo. just had my 5K done and after about 250 miles my infotainment system stops playing music from any source 2 seconds after i come to a complete stop. I have turned off/on radio, bike, speed volume. only used front brake or rear brake. I have stopped in a parking lot stopped with no brakes on and cluch out in n. does not come back. until after i get going about 10 mph sound comes back. bumps in the road does not stop sound from playing.
Does the audio mute or just no volume? To test it, play some music from USB drive and make a mental note where the music cuts out. If when you get back above 10mph it starts playing exactly where you left it, then the audio is getting muted somehow. I'm wondering if the amp is getting enough juice for the turn on lead to happen. If that wire is just loose enough there will not be enough current to power on.
Just a thought. Hope it helps.
I have no route's running on the nav. volume is up. nav prompts are off. I have played with the speed volume on/off up high/down low. i will try what sprok3t has suggested tonight. I will also pull the seat and check all my connections. the dealer had the seat off for the abs brake recall. this is frustrating because it does not do it every stop only 80-90% of the time and that makes it that much harder to pin down. If I take it to the dealer they will have the bike for ever scratching there heads and when it stops 1 time they will think it's fixed.
